Hi steve_gill, Reset Database will refresh the content manager without deleting any files. If you are concerned, you can backup your custom files before proceeding. However, after resetting the database, the content of the previously installed templates will appear as uninstalled. Simply double-click to switch them back to the installed state without needing to download them again. Allen Reallusion
If I run the Reset Database Tool, will I lose all of the content I've added, including my own content?
Sorry, got caught up with other stuff. I will get the information to you shortly.
Hi steve_gill, Did this issue still exist? We need more information in order to help you. Allen Reallusion
Thanks for your reply and feedback. You can try the following methods to see if they solve your problem. 1) In Smart Content Manager, right-clicking on the "Refresh" button & select "ResetMetaData", to see whether this helps? 2) If not, run the Reset Database Tool to check: - https://kb.reallusion.com/Product/53044/How-do-I-restore-the-Smart-Content-Managers-database-to-the-default If the problem persists, we need the following to check: - 1) Running the "Debug View" and start CTA. * The Debug View can get from https://docs.microsoft.com/en-us/sysinternals/downloads/debugview Send the full screenshot of the error code and also the log (in zip format) from Debug View to us for investigation. *** How to: https://youtu.be/5dgmO8JyY54 2) We also provide you with a tool to collect your system information as a file. After the file is generated, just provide it to us (for the PC user): - http://www.reallusion.com/FeedBackTracker/Home/HowToGet 3) Compress the CMS folder into a .zip file & send it to us. %ProgramData%\Reallusion\CMS Important: Duplicate \CMS folder first & zip up the "duplicate" folder. How to: https://youtu.be/AvYz8j--C7M We need all the above data to investigate, & zip up the files before attach here. You can attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. you can use private comment if you want to keep it private. Apologies for the inconvenience caused. Allen Reallusion
