Votes
0
Product:
Character Creator 4
Version:
4.52
Status:
Assigned
Issue 11795
CC 452 gets mixed up with Materials
Please do the following:
- Load attached file
- Select Char
- Open Modify-Material List
- select Mat_5
- delete diffuse map
- UNDO
-- sometimes you need to delete and UNDO severals times, then you get the result seen in the image below.
Either this is a faulty undo buffer or CC gets mixed up with the materials.
Note: Normally mat_6 is for the face, when this error occurs, suddenly mat_19 becomes the material for the face (delete
the diffuse map of mat_19 and youll see the face turns white. Befor the error happens mat_6 is used for the face .
If thats not a bug CC should warn if different materials are mistakely defined for the same mesh on import or something. (second image)
See attached text for download link
OS: Windows 10
  •  2
  •  45
Submitted byK_Digital Feb 5, 2025
COMMENTS (2)
K_Digital Mar 14, 2025
I apologize, please use the new link in the readme below.
Rolf
Feedback Tracker Admin Mar 14, 2025
Hi,K_Digital
Thanks for your feedback.
Your attach file i can't download it,can you regenerate the link? or you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment.
You can also use Private Comment if you want to keep it private.
Best Reguard
Howard
