Votes
0
Product:
Character Creator 4
Version:
4.41
Status:
Active
Issue 11301
Bake realtime subdivision problem
Can't find any description how to use it,realtime subdiv button is not available, gray,not clickable. What is the problem? Tessellation and ordinary subdivision works fine,but i need to divide mesh first and only than export it via GoZ to Zbrush and than be able to send it back is it possible?
OS: Windows 10
  •  3
  •  313
Submitted bygorafume94 May 10, 2024
COMMENTS (3)
gorafume94 May 16, 2024
Ascensi,thanks it's partially fixed my problem,i'm using blender pipeline now,exporting both meshes and than apply detailed mesh as shape key to original.
But still,really looking forward to make this subdivision support character base
Ascensi May 13, 2024
It will only smooth geometry in CC4/iClone.  If you want a character to have high resolution to be smoother,  just use regular smooth mesh by subdivision or apply the body as a soft cloth if you want it to be smooth and have skin physics (must manually paint physics maps - almost completely black character with grey areas to define skin/wrinkle/flab movement) softcloth adds extra resolution similar to smooth mesh by subdivision.   If you want your character high resolution first to send to zbrush for painting or sculpting, this is backwards, it's only necessary to increase resolution in Zbrush to paint or sculp and then you generate the maps from Zbrush to change the smoothness or detailed surface shape via displacement map (manual export from Zbrush then import into CC)
If you want to create a permanent high resolution version of your character, send to zbrush, subdivide then send back to CC4 using no other subdivision levels, only the resolution you need your character to have. You would need to set it to cloth upon import. You can then update the full body skin weight using the Foot/Shoes template unless you have a CC4 full body template already.
After that new high resolution body has the skin weights applied, you can hide the original character mesh if you like or delete it, but if you delete it.  I'm not a Reallusion staff member, this is my own knowledge/insight on the matter.
Feedback Tracker Admin May 13, 2024
Hi gorafume94
This function currently only supports Props and not Characters.
However, you can export Prop to ZBrush via GoZ, sculpt the mesh, and then back to CC, then generate characters by AccuRIG, but in this method, the character will be Humanoid but not Standard CC3+ base.
Thank you.
Tina
