I have 3DXChange 5 and 6 and I noticed the following different behavior, which puzzles me:
- in version 5, I can assign a texture to the Diffuse channel of an imported FBX file and the texture correctly appears - in version 6, given THE SAME FBX FILE, after assigning the same texture in the same way as just described, the texture does not appear
No idea what I am missing: any suggestion is more than welcomed...
Hi Roberto,
The issue you mentioned has been fixed and released in 3DXchange v6.52.
Reallusion
Feedback Tracker Admin
Hi Roberto,
The issue you mentioned has been verified and forwarded to the Developer team, please stay tuned for more updates.
Thank you very much for your generous help.
Reallusion
RobertoColombo
Hi Job,
thanks for the confirmation.
I just sent the FBX file to RL.
Hopefully they will reproduce the issue and fix it.
Roberto
I could actually confirm this in a test. What was weird though was that when replacing another texture of the same item, the new texture did show up. Then when doing an undo, the first texture that I wanted to replace showed up. The thumbnails of the Diffuse files do get updated right away.
RobertoColombo
Hello,
ok, I will send the FBX file in a couple of days because now I am on biz trip.
Regards
Roberto
