Issue 564
64 Bit for next version of 3DXchange?
I sure hope you guys are moving to a 64 bit 3DXchange as I keep getting stupid errors that are solved if I use SketchUp to export FBX.
I have found the current 32-bit version lacking in it's ability to load a large file bigger than 10Mb.
I'm using SketchUp trial to get around this archaic problem.
Submitted byTucsonDoobie
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
Do you want to delete this issue?
