A. You can edit textures to display shop signs |
1. |
Load the shop which you want to edit (e.g. Shop 09) |
2. |
Launch the Diffuse texture of the building by using the photo editing software which you are familiar with (e.g. Photoshop) |
3. |
Use the UV Ref. Function to get _0.bmp as contour lines when editing textures. |
4. |
Compare the iprop and the Diffuse texture, so you can make the sign that you want at the appropriate location. |
5. |
Remove the contour lines, save, and Update. Voila! Your shop is done! |
