You can easily assemble a vehicle |
A |
How to assemble a car. |
B |
Replace/ assemble car elements in the Composer Mode. |
C |
Change the color of the props in Composer Mode/Color Editor. |
For more details, please follow the step-by-step instructions below. |
A. How to assemble a car. |
We have set components' locations and layers for each car's components. You only need to load the car to the stage and you can see a complete car. |
Take the Convertible Front for example. |
A-1 |
Go to Scene > Props and click Convertible Front's folder. |
A-2 |
Double-click every props in the folder and you will have an assembled car. |
A-3 |
Link the props to the Car Body.
Choose the props and select Link, and then click the Car Body. |
Link other props. |
B. Replace/ assemble car elements in the Composer Mode. |
You can replace any car's components and adjust the location of them. |
Take the tire for example. |
B-1 |
Click the props that you want to replace. |
B-2 |
Switch to Props Composer Mode. |
B-3 |
Double click other tires that you want to change in Content Manager to replace it. |
B-4 |
After replacing it, click 'Back to Stage'. |
B-5 |
You have Replaced the props without changing its position. |
C. Change the color of the props in Composer Mode/Color Editor. |
Take the Motorcycle for example. |
C-1 |
Click the props that you want the color. |
C-2 |
Click the Color Editor in Props Composer Mode. |
C-3 |
You can switch the parameters to change the color of it. |
C-4 |
If You want to change the color for other parts of Motorcycle, please select other group such as fairing_02 in Color Editor and adjust it. |
C-5 |
When you finish editing, click 'Back to Stage'. |
C-6 |
Edit the color for other props, and then you can change the color of the entire Motorcycle. |
