![](images/index_01.jpg) |
How to Assemble an Apartment? |
You can create you scene as blow. |
A |
Use Transform Tool to change the location/size of props. |
B |
Replace/ assemble building elements in Composer Mode. |
C |
Change the color of props in Composer Mode/Color Editor. |
D |
Put furniture in your apartment! |
For more details, please follow the step-by-step instructions below. |
A. Use Transform Tool to change the location/size of props. |
A-1 |
Apply the Rooms in Scene/Props.(eg. Room 01 & Room 02) |
A-2 |
Click Room 02 in the Scene Manager. |
![](images/HELP/How to 01/01-03.JPG) |
A-3 |
You can drag Room 02 to a new location directly in Viewport or via Transform Tool. |
B. Replace/ assemble building elements in Composer Mode. |
You can replaced any building elements and adjust the location of any building elements. |
B-1 |
Click Room 02 in Scene Manager. |
B-2 |
Click Props Composer Mode. |
![](images/HELP/How to 01/01-06.JPG) |
B-3 |
Select any building element that you want to replace in Viewport. (eg. Floor 03) |
![](images/HELP/How to 01/01-07.JPG) |
Double click the floor that you want in Content Manager (eg. Floor 02), and you will see that the floor has been replaced. |
B-4 |
You can apply other building elements and move them. |
Tip. When you need to apply other building elements, please make sure that there is no active prop in Viewport. If the prop is active, it will be replaced. |
C. Change the color of props in Composer Mode/Color Editor. |
C-1 |
Click any wall (eg. Wall 01_R ), and then click the Color Editor. |
![](images/HELP/How to 01/01-10.JPG) |
C-2 |
You can change the color of all the walls at once. |
C-3 |
If You want to change the color of the side of the wall, please select Wall 01_R in Choose Group. |
![](images/HELP/How to 01/01-13.JPG) |
C-4 |
When you finish editing, please click Back to Stage. |
D. Put furniture in your apartment! |
D-1 |
Apply the furniture that you want in Content Manger, and place them in appropriate locations via the Transform Tool. |
![](images/HELP/How to 01/01-16.JPG) |
D-2 |
You will see that some furniture needs to be behind a wall (as image above), there are two ways to do this: |
a. You can go back to composer mode and move the wall to the left. |
b. Go in composer mode, and remove the wall. Go back to stage mode and apply a new wall and adjust the Z axis. |
D-3 |
Select all props, and right click to select Add to Scene in Viewport. Click Add in Scene/Scene, and it is done! |
