Indigo Render Plug-in
Physically Based & Photorealistic Renderer
A photo-realistic, cinematic look and feel in iClone's 3D rendering software is now a reality with this iClone Indigo Render Plug-in. Utilize GPU accelerated raytracing render capabilities in Indigo RT, to have your characters, props, and scenes now look completely different than before. To streamline this unique workflow, Reallusion provides automatic shader mapping between iClone and Indigo. In addition, users can perform custom refinement using Indigo's unique shader options, or download Indigo's material library to achieve even better results. Skylight and emissive material settings ensure correct global illumination, and allow for realistic light behavior via reflection, refraction, transmittance, and caustic effects. Furthermore, the physical camera DOF and tone mapping system can be combined with excellent lighting and materials to create vivid and astounding story visuals like never before!
rendering software
DISCONTINUED PRODUCT
One-click Conversion
Physically-based ray-trace rendering can give a 3D scene photo-realistic quality, however the material setup for real-time engines and ray-traced renderers are vastly different. To streamline this unique workflow, Reallusion provides automatic shader mapping between iClone and Indigo. A simple one-click render will automatically convert shader information and provide accurate shader interpretation to your final render. Your iClone characters, props, and scenes will look completely different from before!
  • slidebg1
  • slidebg1
  • slidebg1
  • slidebg1
    Indigo Shader Presets
    In order to deliver the maximum quality and realism for render modes, which aren't covered by auto-conversion rules such as Glossy Transparent,
    Diffuse Transmitter or Coating, the iClone 6 render plug-in provides a set of Indigo Shader presets, each with their own specific sliders which allow
    you to fine-tune your renders to achieve the best results.
  • slidebg1
    rules such as Glossy Transparent, Diffuse Transmitter or Coating, the iClone 6 render plug-in provides a set of
    Indigo Shader presets, each with their own specific sliders which allow you to fine-tune your renders to achieve
    the best results.
  • slidebg1
    the best results.
  • slidebg1
    the best results.
  • slidebg1
    the best results.
  • slidebg1
    the best results.
Download Expansion
Indigo provides massive free material database online for you to download. Those materials can make varied and better visual results on iClone objects' appearances in Indigo, but not affect the objects' original materials in iClone.
