Setting Constraint Limits (New for 5.1)
After a constraint is applied to a rigid body, you are able to set limits to the object's position and the angle, which ensures the constrained rigid body can move or roll within a specified distance or range.
Move
You can use the controls in the Move section to limit the constrained rigid body to move along a specific Local Axis within a certain distance range.
Rotation
You may use the controls in the Rotation section to limit the constrained rigid body to rotate along a specific Local Axis within a certain angular range.
