In iClone, you are able to set keys or add clips into different tracks. Interpolations can be customized between different curves so that the transition speeds between two adjacent keys, or clips, imitate the physical characteristics of how the object would move in the real world.
In the target track of the timeline, set two keys (take the Transform track as an example).
Right-click on the Later one. Select an item from the Transition Curve entry in the menu.
The transition curve will then be generated between these two keys only.
Linear - Constant Speed |
Ease In & Out |
Ease In - Acceleration |
Ease Out & In |
Ease Out - Deceleration |
Step |
With the same concept, you may also set transition curve between two adjacent clips.
Note: |
Please note that you may select multiple keys, or clips, to apply the same transition curve at the same time. |
If you need more dramatic transition results, then you may use the Custom feature provided in the pop-up menu to adjust the steep of the transition curves.
Less dramatic |
More dramatic |
Dramatized transition (Ease In) |
