Exporting a Video
The export video area is split into 4 sections: Format, Output Size, Render Quality, and Output Range.
Format
  1. Use the drop down list to choose AVI, RM, WMV, MP4 or Flash Movie format.
  2. Click the Advanced button to display advanced options. Advanced options are only available when you select MP4 for PC format or Flash Video.
MP4 for PC settings
Flash Video settings
Output size
You can define the size of the exported image in the Output Size field. To define output size:
Select either a Standard Size or define a Custom Size using the spinner arrows.
Note:
  • The HD media files of the AVI format can be selected in the Standard Size dropdown list.
  • The flexibility of the output size depends on the video format you choose. WMV and MP4 have specific restriction on output size defined by the profiles.
  • Render quality
    The render quality can be set to Preview or Final Render using the radio buttons. Check the Anti-Aliased checkbox to export an anti-aliased image. An anti-aliased output will produce an image with less jagged edges and pixilated areas. You may also check the Render Hidden Objects in case some objects are hidden during the editing process.
    Output range
    You can either export the entire video, or just a range of frames. Select the output range using the radio buttons in the Output Range field. You can also select the Frame Rate here using the slider bar. The output range can also be set using the 2 triangle markers below the play bar.
    Click the Export button to export the video.
