Preparing Blend Shapes (New for 5.4 and for Pro only)
A blend shape is a model that is created by modifying a base model mesh so that the two meshes have different shapes with an identical vertex number. In 3DXchange, you can use the blend shapes to change the shapes and appearances of a base character without touching the bones of the character.
Creating blend shapes before Using 3DXChange
You can create the blend shapes before loading the base character and the blend shapes to 3DXchange (In this case, the base character and its corresponding blend shapes are created in Maya).
  1. Create a base character mesh.
  2. Duplicate the mesh and sculpt the new mesh. The new mesh will thus become one of the blend shapes.
  3. Select the new mesh and export it as an OBJ or FBX file.
  4. Repeat step 2 several times to generate different meshes with various morphing styles.
  5. Select these new meshes and export them together as single FBX file.
    Note:
    • If you want to bone-skin the original base mesh and exported the bone-skinned model as an FBX file, then please remember that the rotation data for each bone must be (0,0,0).
    • Please note that you may either export the individual meshes into OBJ or FBX format or export multiple meshes into FBX format.
    • An FBX file with multiple blend shapes can then be loaded into the Morph List.
Sculpting Existing blend shapes
If you want to sculpt an existing blend shape, in order to fine-tune or dramatize the facial expression, then please follow the steps below. This method can be applied to the meshes that are exported from a model before or after the characterization procedure:
  1. Select an existing item that you would like to modify in the Morph List.
  2. Click the Export button to export it as an OBJ file.
  3. Load the OBJ files into your favorite 3D tool and sculpt the mesh of the model.
  4. Save the model to keep the sculpting result.
  5. In 3DXchange, click the Replace button in the Face Setup section.
  6. Load the modified model to replace the select item in step one.
    Note:
    • If the meshes is sculpted by using a base mesh of a character that is yet converted to a non-standard character, then do not import them as blend shapes after you convert the model into a non-standard and vice versa, in order to prevent unexpected mesh-offset issues.
