Using Perform Editor
The Perform Editor in the Animation section determines the animations that will be packed into an iClone prop (*.iProp), or the motions that will be converted into iClone human motions (*.iMotion - for Pro only).
Using Controls of the Perform Editor
Adding Items into the Perform Editor
To add items into the Perform Editor, you need to:
  1. Make sure that you have added a prop or a character in the 3D viewer.
  2. Load animation or human motion files to the Motion Library. Select one file in the list.
  3. Click the Add to Perform or Add All to Perform buttons under the Motion Library list.
Specifying the Motion Names and Trimming Motions
You may change the name, or the set the range, of a selected item to trim the animations or motions.
Specifying the Display Order in the Perform Submenu
