Modifying Texture Settings - Advanced
Diffuse, Ambient and Specular Colors
A. Diffuse Color: The Diffuse color defines the overall color that is reflected on an object.
B. Ambient Color: The Ambient color refers to the illumination surrounding a subject or scene.
C. Specular Color: The Specular color only defines the color of the highlighted area of an object. Therefore, you must decrease the Diffuse color to see the effect.
Diffuse Color =
Ambient Color =
Diffuse Color =
Ambient Color =
Diffuse Color =
Specular Color =
Diffuse Color =
Specular Color =
Opacity
The Opacity setting decides the transparent level of a mesh, but no real-life distortion appears in the mesh bumps.
Opacity = 50
Opacity = 100
Self-illumination
Increasing the Self-illumination value of an object will decrease the light effect of the mesh. This will cause the shadow on a mesh to decreases as well. You may use this feature to create a sky dome or cartoon-like 3D models.
Self-illumination = 0
Self-illumination = 100
Specular and Glossiness
A. Specular: The Specular value defines the strength of the highlighted area of a mesh.
B. Glossiness: The Glossiness value defines the range of the specular on that type of the material.
Plastic:
Specular Value = 35
Glossiness Value = 15
Metal:
Specular Value = 200
Glossiness Value = 10
