iClone provides several methods to clear multiple clips for objects.
Please make sure that you really intend to remove all the motion/animation clips.
Press the Reset button on the play bar.
All the motion/animation clips of All Objects will be removed.
Right-click on the target object whose clips you want to remove.
Select Remove All Animation from the pop-up menu.
Select the target actor.
In the Play Bar, select the desired track from the Action Track Selector list.
Click the
Next / Previous Action Tab
to move the play head to the start frame of the clip you want to delete.
Click the
Delete button to remove the clip.
Please refer to the Quick Tab Bar for Simple Timeline Editing section for more information.
Select an object whose specific track you want to clear.
Press F3 to show the Timeline and turn on the target track.
Double-click on the title of the track to select all the clips in it. Press the Delete button.
All the clips in the track will be removed.
