Modify Panel |
Action (Scroll to) |
Hotkey |
Notes |
Attach Section |
I |
Scroll the Modify panel to the Attach section. |
Look At Section |
O |
Scroll the Modify panel to the Look At section. |
Path Section |
P |
Scroll the Modify panel to the Path section. |
UV Settings Section |
U |
Scroll the Modify panel to the UV Settings section. |
Transform Section |
T |
Scroll the Modify panel to the Transform section. |
Material & Texture Settings Section |
Y |
Scroll the Modify panel to the Material & Texture Settings section. |
Top Section |
L |
Scroll the Modify panel to the Topmost section. |
3D Viewer |
Function |
Hotkey |
Notes |
Full screen mode |
F11 |
Press |
Play/pause |
Spacebar |
For both window mode or full screen mode. |
Roll X-Z |
Right mouse button |
Press down and drag in the 3D viewer to roll the view on X-Z plane. |
Zoom in/out |
Mouse wheel |
Scroll the mouse wheel to zoom in/out the 3D viewer. |
Speed Zoom in/out |
Right + Left mouse buttons |
Press down both the right and left mouse buttons to speed up zooming of the 3D view. |
Tips - Speed movement: holding the Shift key while zooming, panning, rolling and rotating will increase the movement speed by 10x. |
The following table summarizes the hot keys for toggling effects on/off and for performance observation Note:
Action |
Hotkey |
Notes |
Rendering Effects |
Ctrl + F1 |
Switch Shader mode . |
Ctrl + F2 |
Toggle Bump Texturing On/Off. |
Ctrl + F3 |
Toggle Reflection On/Off. |
Ctrl + F4 |
Toggle Glow On/Off. |
Ctrl + F5 |
Toggle Reflection Mapping On/Off. |
Ctrl + F6 |
Toggle Refraction Effects On/Off. |
Ctrl + F7 |
Toggle Water Effects On/Off. |
Shader/Display |
Ctrl + F |
Toggle Frame Rate (FPS) display On/Off. |
Ctrl + G |
Toggle 3D Floor Grid On/Off. |
F1 |
Show Online Help. |
Ctrl + P |
Show Preference Panel. |
F3 |
Show/Hide Timeline. |
Ctrl + Z |
Undo. |
Ctrl + Y |
Redo. |
Ctrl + A |
Toggle World Axis On/Off. |
Ctrl + Q |
Toggle Transform Gizmo Mode On/Off. |
Ctrl + D |
Show/Hide Dummy Props. |
Pop-up Menu |
Right Mouse Button |
Show the Pop-up Menu. |
Camera Switching |
F5 |
Switch to Preview Camera. |
F6 |
Switch between Custom Cameras. |
F7 |
Switch between Follow Cameras (an actor or iProp must be selected) |
Walk/Fly Camera Navigation |
Ctrl + U |
Show/Hide Crosshair in Walk/Fly Camera Mode. |
Director/Editor Modes |
F12 |
Switch between Director Mode and Editor Mode. |
