When you modify the Offset or Tiling settings in the Material & Texture Settings section, you are merely modifying the specific texture to affect only the faces which are covered under the same material ID. The UV of the face and the model are not re-built.
However, once you click the Apply button in the UV Settings section, iClone generates a new UV for the whole model based on the selected UV type and all your previous UV settings are replaced.
The result of the texture is to multiply the number from both them.
Channel UV Settings |
Global UV Settings |
Here we illustrate the difference between the Global UV Setting and the texture
Channel UV Setting.
Given a box with two faces mapped with two different materials.
Go to the Modify/UV Settings section for global adjustment.
Select the Box/Z radio buttons and then set both the Tiling U and Tiling V to 2. Click the Apply button. Two material are affected simultaneously.
Go to the Material & Texture Settings section. Use the Material Picker tool to retrieve the material of the left face.
Set the Tiling U to 2. Press the Enter key.
Only the material on the left face is affected.
