Clearing Clips
iClone provides several methods to clear multiple clips for objects.
Reset All (Edit/Director Mode)
  1. Please make sure that you really intend to remove all the motion/animation clips.
  2. Press the Reset button on the play bar.
All the motion/animation clips of All Objects will be removed.
Clear Clips of a Specific Object (Edit Mode)
  1. Right-click on the target object whose clips you want to remove.
  2. Select Remove All Animation from the pop-up menu.
Clear Specific Clip of a Target Actor (Edit/Director Mode)
  1. Select the target actor.
  2. In the Play Bar, select the desired track from the Action Track Selector list.
  3. Click the Next / Previous Action Tab to move the play head to the start frame of the clip you want to delete.
  4. Click the Delete button to remove the clip.
Please refer to the Quick Tab Bar for Simple Timeline Editing section for more information.
Clear All Clips in a Single Track (Edit/Director Mode)
  1. Select an object whose specific track you want to clear.
  2. Press F3 to show the Timeline and turn on the target track.
  3. Double-click on the title of the track to select all the clips in it. Press the Delete button.
All the clips in the track will be removed.
