Water Edge Softness allows you to reduce the sharpness of the edge to contact surfaces.
Select a water from the Scene Manager.
Under the water modify panel, go to the Advanced Water Parameters section.
Adjust the Edge Softness of the water. By adjusting this parameter you can turn sharp edges into soft edges.
Edge Softness: 10
Edge Softness: 80
