The Tree
iClone provides you with a system to adjust the parameters of planted trees. You may plant trees on the terrain or even link or attach them to some other target object. The trees can cast and receive shadows or sway with the wind during playback. You may then create a forest or potted plants in your project.
To Plant a Tree
It is relatively easy to plant a tree:
  1. Apply your desired terrain and sky. Go to Set/Tree.
  2. In the Content Manger, drag and drop your desired tree into the 3D viewer.
You may even move the trees with the Move, Rotate and Scale tools to manipulate the trees in the same way as props.
Wind
If you increase the Strength value, the trees you plant sways harder when you play the project and vice versa.
Link
Because a tree is similar to a prop, you may link your tree to a target such as a flowerpot.
Before linking.
  • Link to the flowerpot.
  • Align to Parent box checked.
  • Transform data modified.
  • Note:
  • Please note that since trees do not possess any tracks in the timeline, you must be careful when you set Link or Unlink keys to the trees.
