This unique track contains the idle motions of an actor. Since its priority is relatively low, the Idle motion will be ignored during playback if there is any Move, Perform, or Operate motion at the same frame. Please refer to The Rules of Animation Tracks section for more information.
Empty slots will always be filled up with the idle motions in the Director Mode when there are no Move or Perform motions.
Idle motions are randomly chosen from a pre-defined set of idle motions to fill the Idle track.
The Auto Add Idle Motion feature is on by default. However, idle motion can be generated in the Director Mode only, please follow the steps below:
Select the target actor for generating idle motions.
Click the button on the play bar to toggle the Director mode.
Check/Uncheck the Auto Add Idle box to decide whether the idle motions are added.
Start to record and the idle track will be filled up with new idle motions automatically.
