Props can pick a target path after a path is created in the scene. This simple technique allows you to save time by creating key frame by key frame.
Create a path and add a prop to the scene.
Select the prop and click the Pick Path button in the prop's modify panel.
Select the path for the prop to attach to.
Before |
After |
The path name in here represents the path that the prop is currently attached to.
Note:
