Detailing Overall Facial Features
You can create an overall detailed facial expression by adjusting the Model Details in the Head/Faces menu.
  1. Select a character and focus on the character's face.
  2. Toggle to Head/Faces.
  3. Go to the Facial Features section in the Modify Panel.
  4. Click the Detail button to launch the Model Detail window.
  5. Select the blue points to move each Facial region from any of the perspectives: Right, Front or Left.
  6. Front Face
    Result
    Left Face
    Result
    If you have selected multiple points, you can move all the points all at once.
  7. You can select a single point or hold the Ctrl key and drag a rectangular to the select a region of points in the Model Detail panel.
Single Select
Multiple Select
  1. After you have selected a point, the point turns to red which enables you to drag it in the Model Detail panel.
  1. Click the Clear Selection button to clear all the selected red points.
  2. Check Mirror to enable symmetry for both sides of the face.
  1. Click the Reset button to undo the last modification.
  2. Click the Reset All button to revert all changes back to the beginning.
Note:
  • In the selection mode, hold the Ctrl key and drag the mouse to select multiple points.
  • The Detail button in the Head/Faces menu allows you to set the overall facial look, whereas the Face Key feature in Facial Animation allows you to create facial animation for a character.
