The iClone Preview Window provides a visualized Gizmo to handle and modify the RTS (Rotate, Transform, Scale) data of selected objects by dragging the Gizmo on the preview window.
You may turn on the Gizmo mode by means of the Preference panel or using the specified hotkey, Ctrl + Q.
Drag the three circles around the object to rotate it along the 3 axes.
Drag the handles to move the object along the 3 axes.
You may also drag the square at the corner to move the object on the planes of two intersecting axes.
Drag the handles to scale the object along the 3 axes.
You may also drag the yellow cube in the center of the gizmo to scale the object in recent ratio.
Note: |
Only Actors, Accessories, Props, Emitters, Trees and Paths possess a Gizmo.
