The wave of the water utilizes the Normal mapping technique so that the face count of the water remains minimum while the waves can still be extremely realistic.
Please click the Launch button to start your favorite image editor to paint on the image. Remember to save the image after editing.
Click Update button in iClone to see the result.
Note: |
![]() ![]() Non-wrapping images will cause an unrealistic look to the water. |
You may specify the density of the wave image in the water prop by setting the Size value. If you want to change the altitude of the wave, adjust Strength.
Size = 5 |
Size = 30 |
Size = 30 |
