Bring your movies to life with the new enhanced G3 actors:
Better Body Shape: The G3 actor now has a much smoother outline to the body which is retained even when the actor is moving with exaggerated motions.
Normal Map: With the normal map, each G3 actor now has more skin detail without increasing the face count or affecting performance.
Lower Face Count: The G3 actor actually possesses a much more realistic look while amazingly the face count is lower than G2 actors.
Better Skin Texture: The skin texture of G3 actors is designed to contain more defined skin detail, ideal for those close up scenes.
