Add, Import, Rename Commands
AML Script Editor allows you to add/delete ,
rename, import/export the commands and the clips. Follow the steps below
to use each function button.
Add a new command
- Select one of the
major commands you want to add.
- Click "Add".
New idle has been added to the "Command Name" list.
Rename a command
- Double-click on the
"NewIdleCMD" to change the selected command name.
- Add one more idle
command and change the name to "Idle02".
Export command
- Export only the "Idle02"
command for future reuse, have "Idle02" selected
and click "Export iCommand".
Import Command
- Since you have
saved the iCommand, "Idle02", you can now import it into any
other new AML Scripts. Click "Import iCommand" and import the
iCommand we have just exported.
- The iCommand is now
included in the list. Now all the previous settings in "Idle02"will be
set in
this AML Script.
Delete Command
- Delete all the commands could be one of the
options.
- Click "Delete All" to clear all the
commands.
Note: If you want to delete individual command, please press "Delete"
key on the keyboard. You may press "Delete All" button to delete all the commands in the
list.
