You are allowed to export almost every mesh node into an OBJ file for further use in other 3D modeling tools.
Select the mesh you want to export as an OBJ file.
In the main menu, choose File/Export OBJ....
Name the new OBJ file and select the target folder for storing.
Click the OK button to export the avatar as an OBJ file.
Note:
Select the Z-Up or Y-Up radio button in accordance with the 3D tool you want to use to modify the exported OBJ file. Please refer to the Y-Up or Z-Up section for more information.
If you only want to export the selected mesh, then please enable the Export Selected Only box.
Props with embedded iClone DRM (Digital Right Management) cannot be exported as OBJ files.
