Converting Standard or Non-Standard Characters with Motions
When you have a bone-skinned model which contains animations, you can export it via 3DXchange to other 3D tools along with the original animations so that you do not need to create animations again in the 3D tools by using the key-frame method.
In this pipeline, the format for exporting is FBX because this format includes both the meshes and the animations. Therefore, it is suitable when your target 3D tools are Maya, 3DS Max, Unity or Unreal.
Step 1: Loading a Bone-Skinned Model
A bone-skinned model contains bone structure and one or more meshes, while the meshes are bound to the bones so that when the bones move or rotate, the meshes are driven to act along with the bones.
The sources of the bone-skinned models can be:
Step 2: Adding the Motions to the Perform Editor
  1. Scroll in the Modify panel to the Animation section.
  2. Manually drag and drop standard character motion files into the Motion Library; select one of the motions and click the play button to preview. Please refer to the Using Motion Library section for more information.
    Note:
    • If you load a bone-skinned iProp, then its embedded motions will also be automatically loaded into the Motion Library and be converted to standard character motions after you characterize it.
    • Click the Explore button to browse to the default folder for storing the iClone standard characters motion files.
      Windows XP: C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 5 Template\iClone Template\Motion
      Windows 7 or above: C:\Users\Public\Documents\Reallusion\Template\iClone 5 Template\Motion\
  3. Add desired motions into the Perform Editor. Only motions added into the Perform Editor are the candidates for FBX export. Please refer to the Using Perform Editor section for more information.
Step 3: Exporting the Model in FBX Format
  1. Execute the File > Export to Other 3D Format > Export FBX... command..
  2. In the Export FBX panel, use the Target Tool Preset drop-down list to auto-load the settings for the target 3D tools. Please refer to The Settings for Exporting an FBX File section for more information about the details of the settings.
    Note:
    If the target 3D tool is Unity and Unreal, and you want to export more than one motion of the model, then the export method is a little bit different. Please refer to the Exporting Settings for Unity and Unreal section for more information.
  3. Click the OK button to export the model along with its animations in FBX format.
Step 4: Loading FBX in 3D Tools
Import the FBX file into your target 3D tools (Maya, 3DS Max, Unity or Unreal) with the settings below:
Note:
