3DXchange allows you to create props, accessories, 3D scenes possessing the level of the ability to receive light effects in iClone.
Select the desired mesh node.
Check Self Illumination.
Increase the value of self illumination.
Export to iClone and apply to the scene.
Modify the light to check the result.
Light bulbs with various values of Self Illumination in iClone
(Custom Light = Red)
Note:
The Pixel Shader must be turned on to view the effect.
This feature facilitates you to create sky, sun or moon object which are not effected by the light.
