iClone provides a convenient method to use your mouse to pick and edit a character, an accessory or a prop directly from inside the 3D viewer. You may use hotkeys to manipulate the transform data of the selected objects.
In the 3D viewer, double click the mesh you want to select.
You will see the selected mesh node shows its bounding box in the 3D viewer, and the corresponding node is highlighted in the scene tree.
You may now modify the selected node.
Note:
