Appendix A - Supported 3DS Import Parameters
Main Data Structure
Item Name
Parameter Name
Description
Key Frame Mesh
(Object Node)
kfmesh3ds
Scene Tree and KeyFrame data
Mesh
mesh3ds
Triangle Mesh data
Material
material3ds
Material data
Supported Chart
  1. kfmesh3ds
    : Supported : Unsupported : Partial Supported
Data Name
Description
Supported
char3ds name[11]
char3ds parent[22]
ushort3ds flags1
ushort3ds flags2
Name of mesh
Name of parent object
flags field from node header
flags2 field from node header
Point3ds pivot
char3ds instance[11]
point3ds boundmin
point3ds boundmax
Object pivot point
Object instance name
Minimum bounding box point for dummy objects
Maximum bounding box point for dummy objects
ulong3ds npkeys
short3ds npflag
keyheader3ds *pkeys
point3ds *pos
Number of position keys
Loop control flag for position keys
Spline values for position keys
Mesh position keys
Ulong3ds nrkeys
short3ds nrflag
keyheader3ds *rkeys
rfrotkey3ds *rot
Number of rotation keys
Loop control flag for rotation keys
Spline values for rotation keys
Rotation keys
ulong3ds nskeys
short3ds nsflag
keyheader3ds *skeys
point3ds *scale
Number of scaling keys
Loop control flag for scaling keys
Spline values for scaling
Mesh scaling keys
ulong3ds nmkeys
short3ds nmflag
keyheader3ds *mkeys
kfmorphkey3ds *morph
Number of morph keys
Loop control flag for morph keys
Spline values for morph keys
Morph keys
ulong3ds nhkeys
short3ds nhflag
keyheader3ds *hkeys
float3ds msangle
Number of hide keys
Loop control flag for hide keys
Spline values for hide keys
Morph smoothing group angle
keyheader3ds
Data Name
Description
Supported
ulong3ds time
Key's frame position
ushort3ds rflgs
float3ds tension
float3ds continuity
float3ds bias
float3ds easeto
float3ds easefrom
Spline terms used flag
flagged with 0 x 01
Flagged with 0 X 02
Flagged with 0 x 04
Flagged with 0 x 08
Flagged with 0 x 10
  1. mesh3ds
Data Name
Description
Supported
char3ds name[11]
byte3ds ishidden
byte3ds isvislofter
byte3ds ismatte
byte 3ds isnocast
byte3ds isfast
byte3ds isnorcvshad
byte3ds isfrozen
Object name
Hidden object flag
Lofter visibility flag
Matte object flag
Doesn't cast shadow's flag
Fast display flag
Doesn't receive shadows
Frozen object flag
ushort3ds nvertices
point3ds *vertexarray
ushort3ds nvflags
ushort3ds *vflagarray
Vertice count
List of vertices
Number of vertex flags
List of vertex flags
ushort3ds ntextverts
textvert3ds *textarray
Number of texture vertices
List of texture coordinates
byte3ds usemapinfo
mapinfo3ds map
Boolean for use of mapping icon information
Mapping icon info
Float3ds locmatrix[12]
Object orientation matrix
ushort3ds nfaces
faced3ds *facearray
ulong3ds *smootharray
Face count
List of faces
Smoothing group assignment list
byte3ds useboxmap
char3ds boxmap[6][17]
Boolean used to indicate the use of box mapping
Material names used in box mapping
ubyte3ds meshcolor
UI color assigned to the mesh
ushort3ds nmats
objmat3ds *matarray
Assigned materials count
Material assignment list
byte3ds useproc
ulong3ds procsize
char3ds procname[13]
void3ds *procdata
Use animated stand-in flag
Size of animated stand-in data
Name of animated stand-in procedure
Animated stand-in data
  1. Material3ds
Data Name
Description
Supported
char3ds name[17]
fcolor3ds ambient
fcolor3ds diffuse
fcolor3ds specular
Name
Ambient light color
Diffuse light color
Specular light color
float3ds shininess
float3ds shinstrength
float3ds blur
float3ds transparency
float3ds transfalloff
float3ds selfillumpct
float3ds wiresize
Shininess factor
Shininess strength
Blur factor
Transparency factor
Fall off factor
Self illumination percentage
Width of wireframe
shadetype3ds shading
byte3ds useblur
byte3ds usefall
byte3ds twosided
byte3ds selfillum
byte3ds additive
byte3ds usewire
byte3ds usewireabs
byte3ds facemap
byte3ds soften
Shading type
Blurring flag
Transparency falloff flag
Two sided material flag
Self illumination flag
Additive transparency flag
Use wireframe rendering
Wire size is in units, not pixels
Face mapping switch
Soften switch
mapset3ds texture
mapset3ds texture2
mapset3ds opacity
mapset3ds bump
mapset3ds specmap
mapset3ds shinmap
mapset3ds illummap
rmapset3ds reflect
Texture map settings
Second texture map settings
Opacity map settings
Bump map settings
Specularity map settings
Shininess map settings
Self illumination map settings
Reflection map settings
mapset3ds
Data Name
Description
Supported
bitmap3ds map
bitmap3ds mask
The map settings
The mask settings
bitmap3ds
Data Name
Description
Supported
char3ds name[13]
Bitmap file name
float3ds percent
tiletype3ds tiling
byte3ds ignorealpha
Strength percentage
Tile/Decal/Both
Filtertype3ds filter
float3ds blur
byte3ds mirror
byte3ds negative
float3ds uscale, vscale
float3ds uoffset, voffset
float3ds rotation
Pyramidal/Summed Area
tinttype3ds source
fcolor3ds tint1
fcolor3ds tint2
fcolor3ds redtint
fcolor3ds greentint
fcolor3ds bluetint
RGB/RGB Luma Tint/Alpha Tint/RGB Tint
ulong3ds datasize
void3ds *data
Size of procedural data
Procedural data
