Download
Buy
Upgrades
CrazyTalk6 PRO Trial Download
Select the location where you wish to download:
Click the download link below to begin your FREE trial download. (See the differences between trial and full version)
Reallusion Download
Free Download: 87.5 MB
CrazyTalk6 PRO Edition release: 11th June, 2009
Note: CrazyTalk6 can run alongside with 5.x program. You can install CrazyTalk6 trial or full version without removing CrazyTalk 5.x program from your system.
Installation Instructions:
Follow these instructions to install CrazyTalk6 PRO Trial Edition:
1. Locate and run "crazytalk.exe". Click OK to start the InstallShield Wizard.
2. You will see the "Welcome to CrazyTalk Setup" screen Click Next to begin installing the CrazyTalk program.
3. Read the License Agreement and click Yes only if you accept the terms.
4. Click Next to use the default destination folder or click Browse to select a different folder and then click Next.
5. Click Next to select the default program folder; alternatively, you can type in the name of a different folder or select one from the Existing Folders list, then click Next. Setup will copy files to the disk.
6. Setup will complete copying program files to your system and updating the register. You will see the "Setup Complete" screen. Click Finish to complete the installation.
System Requirements:
Hardware
Pentium IV 2GHz (2.4GHz or higher recommended)
512MB RAM (1GB or higher recommended)
1GB disk space (2GB or higher recommended)
Duplex Sound Card/VGA Card/Keyboard/Mouse/Microphone/Speaker
Software
Windows XP SP2/Vista
Browsers: Internet Explorer 6 or above, Firefox 2 or above
DirectX 9 and WMEncoder 9 are required for WMV exporting
View CrazyTalk5 System Requirements
What is the difference between the Trial and Full version?
Item Trial Full
Program Time limit 2 days No limitation
14 days (after registration)
Media export with a watermark Yes No limitation
Full length project playback & output Yes Yes
Save function (Model, Script, & Project) No Yes
Output format (MP4) No Yes
Output size DVD DVD (Standard)
HD (PRO)
Data Embedded Project 3 6
6 (after registration)
Embedded Model 14 28
Embedded SFX 89 163
