The blending can happens between clips in
a single track or in different tracks. The rules are listed below:
Blending Between Clips on Motion Clip and Auto Motion Tracks
By default, motion clips will blend with the clips (auto motion or idle
motion clips) in the Auto Motion
track,
which makes the transition between two motion clips smoother.
If there is no clip shown in the Auto Motion track, then
when you play back the project, the actor will be still within
these empty time frames until it goes to the start frame of
the blending part of the next motion clip.
Blending Between Clips on Single Track
If you wish to manually blend two clips together,
then follow the steps below:
Pick the latter of the two clips. The blending part will be shown before the clip.
(Empty rectangle)
Drag the clip to connect to the previous clip.
The actor will gradually change the facial movement during the interval duration.
