The general output settings for Video, Image, and Web are described in this section.
Check the Export Specified Section option if you only want to export a specific part of the project.
You may also drag the Mark in/Mark out controls beneath the play bar (the red triangles in the illustrator below) to specify the range to be exported.
Select the Original Resolution option if you want to retain the same resolution as the source image.
Check the Target Resolution option if you want to specify your own target resolution. Select the desired resolution from the drop-down box. You can select from DVD or VCD with PAL/NTSC formats.
Select the Crop option if you only want to export a specific area of the image.
Select the Use Full Image option if you want to display the complete talking image without cropping it.
Specify your own desired resolution for the output frame by entering the height and width in pixels in the Output Size boxes.
Enter the desired frame rate in frames per second in the Frame Rate box.
Click the Border Color box to specify the border color of the preview window. You may also change the border color in the preference panel.
