Using the Key Editor, you can also set or modify the rotation/tilt keys for the character.
Select the Head Rotation
button in the pane.
If you are using the mouse as your input device, please press and hold the left mouse button inside the facial feature pane.
Move the mouse around, the model will rotate its head to match the mouse movement.
Initial View |
Mouse Moves Left |
Mouse Moves Right |
Click the Set Key
button to save the changes into the key.
Select the Head Tilting button in the pane.
Move the mouse left and right to tilt the model's head accordingly.
Initial View |
Mouse moves left |
Mouse moves right |
Click the Set Key
Note:
