You can create your own unique puppet profile or modify existing profiles from the Edit Property pane.
Click the Clear Selection button to deselect all features.
Pick the desired features in the Solo Feature Selection pane.
Click the Preview button, press the Space bar, and move your input device (mouse by default) to preview the movements of the selected features.
If you are satisfied with the result, click the Save Profile button to save your custom profile.
To customize your own puppet control profile, you may want to adjust the weight of each feature manually.
Click the Edit Property button to expand the weight pane.
Modify the values in the Weight column of the corresponding feature to specify the weight of the movements triggered by the movement of your input device.
Do steps 3 and 4 repeatedly until you obtain satisfying results.
Click the Save Profile button to save your custom profile.
