CrazyTalk lets you to save models under the Custom part of the image gallery. You can modify a template image or create a talking image from an imported image of your choice, use the fitting and image processing tools to prepare the image for animation, and then save the model image for future use.
To save an image, do one of the following:
Click the Add
button to add the model to the custom model gallery. You can rename the image
and save it to a desired folder using the tools at the top of the image gallery.
After you are satisfied with the model and the color, size,
and motion attributes, click the Overwrite
button in the image gallery to save all the
changes to the selected model file.
Note: |
