You can select an image to create a model by importing an existing image from a file/folder, or by using one of the models from CrazyTalk's image gallery. You can also save your models as customized models and re-use them for future projects.
Note: |
To choose an image to create a model, do one of the following:
Click the Import Image
button to import a jpg or bmp image. The Open dialog box appears. Browse to select
a photo or an image file you would like to use. Click the Open button to open the sample file.
Click the Camera Capture
button to take a picture with your webcam.
Select the webcam you wish to use from the Device drop-down list.
(If your web camera is not on the list, please click the Refresh button to refresh the device list)
Specify the resolution from the Resolution drop-down list.
Click the Capture button to take a picture with the selected webcam.
(The content of the preview window will be captured and displayed on the right pane)
Click the OK button to confirm the captured image and exit.
