You can add your own background image or a background with the color
of your choice using the Background Mask Settings. Click Background
Settings
to specify the background
color or image.
Click Color to specify a color background. Select a color from the color palette displayed.
Check Original Background if you want to leave the background unchanged.
Check Color Background to use the specified color as the background color.
Check Import to choose your own background image. Click Browse to specify the name and location of the image.
Specify how you want the image to be placed using the Position drop-down box.
![]() The original look |
![]() Define the background area |
![]() Image imported as the background |
![]() The result |
