On the output page, you may export your project for Video, Widget, Web, or YouTube.
Select the desired media type from the four tabs.
Tab |
Video |
Widget |
Web |
YouTube |
Available Format |
AVI MP4 RM Sequenced BMP, TGA and PNG WMV WAV |
iWidget |
Flash RM WMV |
FLV |
Note:
Check the Export Specified Section option if you only want to export a specific part of the project.
You may also drag the Mark in/Mark out controls (the red triangles in the illustrator below) beneath the play bar to define the part for exporting.
Select the Original Resolution option if you want to retain the same resolution as the source image.
Select the Target Resolution option if you want to specify your own target resolution. Select the desired resolution from the drop-down box. You can select from DVD or VCD with PAL or NTSC formats.
Select the Crop option if you only want to export a specific area of the image.
Select the Use Full Image option if you want to display the complete talking image without cropping it.
Specify your own desired resolution for the output frame by entering the height and width in pixels in the Output Size boxes.
Enter the desired frame rate in frames per second in the Frame Rate box.
Click the Border Color box to select the border color from the color palette.
If you are in Widget or Web (Flash format) mode, you may need to modify the Quality Settings for video and audio.
(Click the Advanced button in Web (Flash format) to show the Quality Settings panel.)
The HTML options are available if you are in Web mode:
Check the Produce HTML Page to create an HTML page with the media content (Flash, RM and WMV) embedded in the file. The HTML file is saved in the same location as the media file.
Check the Including Standby Motion so the model possesses standby motions when the media is not played.
You may need to apply for a YouTube account to directly upload your CrazyTalk project to YouTube.
Type in your Account and Password. You may check the Remember Account checkbox so you don't need to re-type it next time for uploading.
Specify the Output Size from the drop-down list.
In the File Settings, type texts into the Title, Description and Tags fields.
Choose a Category from the drop-down list so other users may easily find your video.
The Public checkbox defines if you wish your video to be public or private on YouTube.
Click the Go to YouTube button to
open the Log on page of YouTube in your internet browser.
Click the Upload button to start
uploading the project to YouTube.
