The Script page is the critical phase in CrazyTalk's process of creating talking images. Here you decide what and how your models talk and specify expressions, facial movements and special effects that go along with the animated script.
Note: You can download additional text-to-speech voices from Microsoft or browse Reallusion website for more information.
There are three methods to modify a talking script:
Double-click or right-click (select Edit in the right menu) on the target script in the Stage.
Select a script in the track and click the Timeline tab in the Stage panel.
In the Timeline Editor, select the target script in the script drop-down list.
There are 4 methods to add expressions to a talking script:
A. Emotives Library
Click the Emotives tab to view a set of basic templates such as sad, angry, happy, and more. Double-click on the desired template to apply it.
You can adjust the strength of the expression on the model's face by using the
slider.
B. Motion Clip Gallery
Drag-and-drop the desired template from the Motion Clip gallery.
(These templates contain expressions and special effects)
To create a custom motion clip, drag to select the desired portion in the Motion Clip track and click the Group
button.
C. Utilizing Puppeteering Panel
Click the Puppet Control
button to invoke the Puppeteering Panel to create custom motion clips. A motion clip will be overlapped as the top layer of the Face, Transform, Eyes or Shoulders tracks.
Select a Puppet Profile and full face control, click the Preview button and press the Space bar to view the result. Click the Record button when you are satisfied with the settings.
Pick a desired profile and click the Record button, then press the Space bar to start recording the motion clip. Move your mouse to move the model, the movements will be recorded simultaneously. Press the Space bar again to stop recording.
D. Setting Keys
There are two methods to set keys to individual tracks:
Double click on any empty place of each track to invoke the related dialog box to add desired template.
Track
Double Click
Description
Voice
Select all tracks.
Lips
Invoke Lip Synching dialog box.
Select desired template.
Adjust the strength.
Motion Clip
No reaction
Drag in this track to make a range for creating custom motion clips.
Group the data from Transform, Face, Face Strength, Head, Eye, Shoulder, SFX and SFX-Swap to convert into one single Motion Clip.
Transform
Invoke Key Editor dialog box.
Set transform keys for Models manually or automatically.
Face/Face Strength
Invoke Facial Expression dialog box.
Adjust the strength of the expression.
Modify the Facial Feature and Muscles.
Add/Delete customized template.
Head
Set keys for Head, Facial Muscles, Eyes, and Shoulders manually or automatically.
Specify the Facial Muscles in an Expression key.
Eye
Shoulder
SFX/SFX-Swap
Invoke the Special Effect dialog box.
Select Image Theme, Image Overlay, and Text SFX as special effect.
Type texts as the contents of the text special effects.
Two tracks of SFX for creating more special effects in the front or background of the image.
Invoke the Key Editor panel, pick Head, Transform, Eyes or Shoulders in the Key Editor panel, drag on the sample image to adjust the model, and click the Set Key button to add a key into the timeline. Check the Auto Key box to update the key automatically instead of having to press the Set Key button manually.
Note: |
