You can create your own customized CrazyTalk Models using any digital snapshot of yourself, a picture of your friends, colleagues, family members, i.e. any photo from your digital camera.
Loading Image
There are two ways to load your image:
Import Image: Click to import a jpg, bmp, tga or png file with one or more faces to generate models.
Camera Capture: Click to take a picture with your web camera. Another panel will open for capturing an image.
Cropping, Rotating and Enhancing Imported Image
Image Processing is the first step of the wizard. You may also click the Image Processing
button to open the image processing tools and enhance the image after exiting the wizard.
Crop Image: Select the required image area.
Rotate CW / Rotate CCW: Rotate the image by 90 degrees in the clockwise or counter-clockwise direction.
Mirror: Mirror the image on the horizontal axis.
Smart Level: Adjust the color levels of the image automatically.
Color Level: Adjust the brightness, contrast, hue and saturation levels of the image manually. Use the sliders in the menu box to adjust the values or enter the numerical values for each parameter in the boxes next to the sliders.
Color Balance: Adjust the color balance manually. Drag the sliders to adjust the Cyan - Red, Magenta - Green, and Yellow -Blue levels. Click Highlights to apply these color settings to emphasize the brighter areas. Click Midtones to apply these color settings to the entire image with average intensity. Click Shadows to apply these color settings to emphasize the darker areas in the image.
Face Fitting
The Face Fitting step is next. Click and move the indicators numbered 1, 2, 3, and 4 on the image to provide the four points for the fitting process as displayed in the sample image. You may also click the Face Fitting
button to start the Face Fitting step again after exiting the wizard to add or delete models.
Adjust the four points as close to the correct position as possible to get the best fit for the eyes and mouth features.
If you merely want to have a single model in the project, please skip the following steps.
To generate multiple models (you may add up to four models):
Click the Add Model
button.
Drag on the image to select another character on the image. Please note that the top left corner of the cursor is the base for framing out a model.
Locate the four feature points again to best fit the new model's eyes and mouth features.
You may click on the target quadrilateral and click the Delete Model
button to remove the model.
Click the OK button when you finish adding models and go to the next process.
(3D) Face Orientation
The Face Orientation step displays. Here you may assign different face styles to every model by clicking the model on the image and then selecting a suitable style.
You may also click the Face Orientation
button to invoke the Face Orientation step again after exiting the wizard to re-assign different face styles to each model.
Utilize the
tool to rotate the oval wire to best fit the orientation of the face on the image. Do not worry if the wire does not perfectly fit the face on the image since this panel is only for deciding the rotation strength of the profile.
Strength: Drag the slider to adjust the movement strength of the profile as the model rotates.
Preview: Toggle this button and move your mouse around to see the effects of the Strength in the viewport. Toggle it again to leave the Preview mode.
Click the OK button to exit the wizard and go back to the model page with the newly-generated models. You may click the
, and
buttons on the Model page to re-launch the panels above to change the settings.
Separating Models from Background
Click the Background Mask Editing
button to modify the area of the image that reveals the background image, which does not move along with the talking models.
If you load TGA or PNG images with alpha channel, the alpha channel will be automatically converted into the Background Mask.
Note:
The background mask, also known as the alpha channel, controls the transparency of TGA or PNG images.
The mask is defined by the blue area.
The mask does not actually show up on the model. It is for your reference only.
Please make sure the mask does not cover any model.
Full: Extend the background mask over the complete image area.
Clear: Delete the background mask.
Inverse: Invert the background mask area. The area that was previously defined as the background mask and the animated area are swapped.
Paint: Paint on the image to enlarge the background area or add more parts to it.
Erase: Paint to erase parts of the background mask.
Brush Size: Drag the slider to adjust the size of the brush tool.
Mask Color: Click and specify the color for the background mask via the color palette.
Opacity: Drag the slider to specify the opacity of the background mask.
Contract/Expand: Drag the slider to contract or expand the background mask.
Blur: Drag the slider to blur the edges of the background mask.
Preview: View the results of your editing.
Fine Tuning Face Fitting in Wireframe Mode
CrazyTalk automatically generates a wire-frame surrounding the face according to the 4 points you set in the Face Fitting panel. You may click Basic Facial Mode
or Detailed Facial Mode
to view the wire-frame. Drag the control points or the lines to fit the character’s face much more precisely in these two modes.
Please also use the
tools above the viewport to zoom in/out or pan the image to locate the points more precisely.
Basic Facial Mode
Zoom in for Editing
The wire-frame structure is divided into two parts, Character Frame and Head Frame (includes Skull Mesh and Hair Mesh).
Character Frame
Head Frame
Skull Mesh
Hair Mesh
The character frame decides the range on the image to generate a model.
Cover the whole body of the character on the image with the character frame so the whole model can be transformed in the timeline editor.
The skull mesh is used to frame out the skull, eyes, nose and mouth of the model.
The more proper the points are aligned, the better the facial animation the model presents.
The hair mesh, also known as Pharaoh mesh, is used to frame out objects attached to the head such as hair, hat or long ears (of animals).
It prevents the image from breaking and increases the realism as the model rotates.
Defining Custom Background
Click the Background Settings
button to specify a solid color or an image as the background.
Color: Click to specify a solid color as the background.
Background:
Original Background: Use the background of the original image.
Color Background: Select this button to enable the solid color as background as specified in the previous step.
Import: Browse to your desired image and apply it as the background of your project. You may also specify the Position of the image in the background.
The original look
Define the background area (blue area)
Scene image imported as the background.
Result
Specifying Virtual Eyes
Click the Eye Settings
button to specify the settings for the Eyes.
Select one of the eye templates from the Eye Style drop-down list.
Click Modify. You may then adjust the position and the color of the Eyeball, Eyelash, Eye Shadow as well as the Specularity of the eyes.
Before
After
You may also click the Import
button to import custom images (JPG, BMP, TGA, PNG,) with or without alpha channel as the texture of the character's Eyes (256 pixels x 256 pixels).
Specifying Virtual Teeth and Inner Mouth Color
Click the Mouth Settings
button to specify the settings for the Teeth, Mouth and Lips.
Before
After
button to import custom images (JPG, BMP, TGA, PNG,) with or without alpha channel as the texture of the model's Teeth (256 pixel x 166 pixels).
Assigning Standby Motions
Pick the model and click the Model Motion Settings
button to assign different Standby Motions to individual models. The models' head will rotate when they are not speaking.
Now you are ready to create a CrazyTalk stage. Please refer to Creating a Stage for more information.
