Setting the Head Keys
CrazyTalk 5 PRO Edition only.
Using the Key Editor, you can also set or modify the rotation/tilt keys for the character.
Including the Rotation Status into a Key
  1. Select the Rotation in the pane.
  2. If you are using the mouse as your triggering device, please press down and hold the left mouse key inside the facial feature pane.
  3. Move the mouse, the model will then rotate it's head and track the mouse.
Initial View
Mouse Moves Left
Mouse Moves Right
  1. Click Set Key button to include the changes into the key.
Including the Tilt Status into a Key
  1. Select the Tilt in the pane.
  3. Move the mouse left to tilt the model's head left and move the mouse right to tilt the model's head right.
Initial View
Mouse Moves Left
Mouse Moves Right
Note:
  • Check the Auto Key box so that you don't need to click the Set Key repeatedly. The Key Editor automatically includes the status of features on each mouse-up event.
