Setting the Camera Keys
CrazyTalk 5 PRO Edition only.
Using the Key Editor, you can also set or modify the Pan/Zoom/Rotation keys for the character.
Including the Pan Status into a Key
  1. Select the Pan in the pane.
  2. If you are using the mouse as your triggering device, please press down and hold the left mouse key inside the facial feature pane.
  3. Move the mouse, the camera will then pan the image along with the movements of the mouse.
Initial View
Mouse Moves Up
Mouse Moves Down
Mouse Moves Left
Mouse Moves Right
  1. Click Set Key button to include the changes into the key.
Including the Zoom Status into a Key
  1. Select the Zoom in the pane.
  3. Move the mouse up to zoom in and move the mouse down to zoom out the image.
Initial View
Mouse Moves Up
Mouse Moves Down
Including the Rotate Status into a Key
  1. Select the Rotate in the pane.
  3. Move the mouse left to rotate the camera counter clock wise and move the mouse right to rotate the camera clock wise.
Initial View
Mouse Moves Left
Mouse Moves Right
Note:
  • Check the Auto Key box so that you don't need to click the Set Key repeatedly. The Key Editor automatically includes the status of features on each mouse-up event.
