If you have a project with keys edited, you can select partial sequence to create a custom motion clip for further use.
Drag on the Motion Clip track to select a partial sequence.
Right click in the selected sequence and choose Group in the menu.
You may also click the Group button.
Before Grouping |
Selection on Motion Clip Track |
After Grouping |
Click to select a motion clip.
Right click on it and select Ungroup. You may also click
Ungroup button. The keys
in the motion clip will be dissected and then can be edited individually.
Note: |
If the property boxes of the motion clip are checked, ungrouping motion clip will keep the keys in the overlapped area. |
