CrazyTalk lets you to save a talking image as a model under the Custom part of the image gallery. Thus you can modify a template image or create a talking image from an imported image of your choice, use the fitting and image processing tools to prepare the image for animation, and then save the model image for future use.
For saving an image, do one of the following:
After you are satisfied with the model and the color, size,
and motion attributes, click Overwrite
in the image gallery to save all the
changes to the image.
Alternatively, click Add
to add the model to the model gallery.
The new model is added to the custom image gallery. You can rename the talking image
and save it to the desired folder using the tools at the top of the image gallery.
You can also save the image as a Face JPEG image by clicking the
button.
This format saves the model image along with fitting information, wire frames, and
control points. Specify the name and location of the file and click
Save. The next time that you use this
image for creating a CrazyTalk character, you will not need to do the fitting process.
Note: |
