You can add a your own background image or a background with the color
of your choice using the Background Mask Settings. Click Background
Mask Settings
to specify the background mask.
Click Color to specify a color background. Select a color from the color palette displayed.
Check Original Background if you want to leave the background unchanged.
Check Color Background to use the specified color as the background color.
Check Import to choose your own background image. Click Browse to specify the name and location of the image.
Specify how you want the image to be placed using the Position drop-down box.
Check Enable Camera Movement so you may edit the camera key in Timeline.
Check Lock Background box if you intend to have a still background when the camera moves. Uncheck this box and the background will be driven to move along with the camera movements.
The Position drop down list is enabled if you lock the background image. You may specify the background image to be centered, tiled or stretched.
