In the Project Setting panel you may adjust the length of the project, the time unit shown on the time counter, the viewing method of the camera and the background.
Click the Project Setting button to open the Time Setting panel.
Project Setting Button
Project Setting Panel
The camera setting decides the viewing method of the camera.
Two items of identical size viewed 3D view |
The farther item looks smaller than the front one
Two items of identical size viewed in 3D view |
The distance does not affect the size of the |
Lens = 35 (Fish Eye effect) The Z-depth relationship is strong. |
Lens = 200 The Z-depth relationship is less. |
In this section, you may set the background of your project to a solid color or to a prepared image.
Prepared Image |
Stretched |
Fit |
Tiled 2 X 4 |
By default, CrazyTalk Animator compacts all loaded
video files into a project file, which increases the total size of the project.
To prevent this, you may click on the External Files button to have all the video files saved as external files.
This can solve the over-sized project issue. However, do remember to move all the
video files together, along with the project file if you move the project to another folder destination.
